MSS37448
Aug 17, 2023Aspirant
ORBI 853 Ghost Satellite
 Hi Guys,  I am in the UK.  System configuration  Virgin Media Hub 3 set in Modem Mode.  Download Speed 1Gig Fibre, Upload 100Mbps  ORBI 853 [850 Router and  2 Satellites  Firmware Version 4.6.14.3-2....
- Aug 18, 2023
Good morning FURRYe38,
Apologies for long missive…..
Firstly the bad news, the Ghost Satellite [Satellite-1] is back again.
However, the good news is that assigning reserved IP address appears to have stopped Satellite-L from losing sync and even though the network map shows 3 connected Satellites, however, the Ghost Satellite-1 is not connected and therefore apparently not interfering with Satellite-L, at least not so far today!
After the factory Reset, the Satellites reverted to Satellite numbers 1 and 2.
Once I had reserved the IP addresses and power cycled the Orbi devices, I reverted both Satellites names back to B and L, ensuring that I was assigning the names based on the MAC addresses previously used.
The web Interface shows Satellite-1 is disconnected and the option to remove this device is available. Satellite 1 removed.
So partial success, I may have to contact the dreaded Network Support Team, unless you have some further suggestions, which would be greatly appreciated.
To summarise the steps undertaken so far:
1. Factory Reset the RBK853 Kit, [Router and 2 Satellites]
2. Power Cycle the Modem and wait for LEDs to go solid
3. Power Cycle the Router and wait for LEDs to go solid
4. Using web Interface added one Satellite at a time [Starting with L]
5. Assign Reserved IP addresses to both Satellites
6. Power Cycle the RBK 853 Kit
7. Verify reserved IP addresses are now assigned to the Satellites by the system
8. Revert Satellite Names to B and L, as per previous Configuration
9. Remove Disconnected Ghost Satellite [Satellite-1] from list of connected Satellites via web interface. [even though the Ghost Satellite has been the disconnected the web Interface is still showing 3 Connected Satellites]
10. Verified that the Backhaul Status for Satellites B and L is reported as Good.
Aug 17, 2023Guru - Experienced User
A factory reset and setup from scratch resolved others seeing ghost RBS appearances.
I'd start with adding the RBS-L to the system after you reset and setup from scratch.
I might set up a IP address reservation as well for each RBS.
Use MS Edge or Firefox browser to setup the system.
MSS37448
Hi Furrye38
Thank you for the prompt reply and the guidance.
2 questions please, if I may
Why MS Edge or Firefox, instead of the Orbi App?
How do I setup a IP address reservation for each RBS?
- FURRYe38Aug 17, 2023Guru - Experienced User
Browsers have more granular user options and view of the features of the orbi system. And you'll need to use one if your going to reserve an IP address for the RBS: https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
- MSS37448Aug 17, 2023AspirantHi Furrye38,
Thank you for the advice and the note on IP reservation.
Reset session planned for later this evening. (May be a long night)!
Will post the “Result” here.- FURRYe38Aug 17, 2023Guru - Experienced User
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System < I prefer this method.
