SonicGT
Feb 20, 2023Aspirant
Orbi 860 can’t connect to my western digital nas
I had an old Orbi system and decided to upgrade. For the most part everything worked fine. But while it sees my NAS which is connected to an Ethernet port on the router I can’t connect to it. I can’t ...
CrimpOn
Feb 20, 2023Guru - Experienced User
Trying to connect to the NAS
- From a device on the same LAN, or
- From a remote device?
SonicGT
Sorry forgot to get that specific
Local network. I tried wireless in the same Wi-Fi network first then tried to hardwire my laptop to Orbi as well so both were Ethernet and same issue.
- CrimpOnFeb 20, 2023Guru - Experienced User
Is the NAS connected directly to the Orbi router Ethernet port, or through a switch of some kind?
I forget how Western Digital NAS systems are managed: is it through a web interface? or an "app" that goes out and finds the NAS?
- SonicGTFeb 20, 2023AspirantIt’s connected directly to the Orbi. I used to have a switch with my old Orbi since it only had 1 port but now with the 860 I eliminated the switch completely.
The wdnas I have uses a web console.
As a troubleshooting step to make sure my nas didn’t die. I plugged my pc and nas into my old switch off my network completely and was able to get to it. So I know the nas is still good- CrimpOnFeb 20, 2023Guru - Experienced User
There have been posts on the forum regarding issues with Ethernet ports on various Orbi models.
It is simply goofy that the Orbi Attached Devices page would show the NAS as connected with an IP address, but not able to be reached.
The NAS receives the LAN IP address from the router using DHCP, correct? (not set on the NAS system itself as a Static IP)
