rossowheelws
Nov 02, 2023Aspirant
ORBI 860 CONNECTIVITY
I currently have an ISP who provides a router/modem and I am looking to replace this with an ORBI 860 setup. Please could I ask whether a modem will be required and which Netgear model is suitable? T...
rossowheelws
Thanks for your recommendation. The ISP will require me to return their equipment when the contract ends. I intend to then look for the cheapest provider who will probably send me their equipment to use. I would prefer to use my own modem and router going forward as my ISP will change over time. I have a larger property circa 4000sqft over two floors and standard routers don’t provide full coverage even with five extra discs.
Nov 03, 2023Guru - Experienced User
Orbi with the RBR and two satellites should work well.
Good Luck.
