Aged-one's avatar
Aged-one
Orbi 860 Rediculous price
Hi,
  I do have poor wifi  signal from my router in my study/games room  into my kitchen (Smart TV) so I'm unable to use the internet on the tv.
 I looked at what was available from Netgear by answering  some questions and up popped a recommendation for the Orbi860 system. however at ÂŁ1000+ No Way. !!
  I will look elsewhere.
  • FURRYe38's avatar
    So try a 7 series?
    Or maybe a MK90 series MESH system?
    • Aged-one's avatar
      Aged-one
       Hi FURRYe38,
       Thanks for the response and recommendations. I will look again.
       It was the Orbi860 that was recommended but unrealistic price, I probably need a wifi extender to reach the kitchen in my small/medium sized house ? I'm unsure if your recommendations are for extenders or a completely new router? I will look again. Virgin currently supply my router.
      my wifi is Virgin 500gb speed.
      • FURRYe38's avatar
        Well recommendations are just recommendations. I know cost is different between your region an USA.
        For what you have and do, you don't need the 10Gb WAN port which I don't fully understand why NG came out with that and not have higher speed ports on the LAN port site. There still max at 1Gb. So for the ISP speed you have, the 860 would not make sense. I would not recommend it. The 750 series or MK series would make much better sense.
        What is the size of the home if I might ask? Sq feet please.
