nadrux
Dec 29, 2024Tutor
Orbi 860 ssid iot or 850
hello i wanted to know if those models have the ssid iot feature ? and wich is better to buy in term of update futurproof etc. (860 is from 2023 and the other from 2020) than you !
Dec 29, 2024Guru - Experienced User
Since the 860 series has FW v7 support, yes, it has the IoT support as well.
