nadrux
Dec 29, 2024Tutor
Orbi 860 ssid iot or 850
hello i wanted to know if those models have the ssid iot feature ? and wich is better to buy in term of update futurproof etc. (860 is from 2023 and the other from 2020) than you !
Dec 29, 2024Guru - Experienced User
Since the 860 series has FW v7 support, yes, it has the IoT support as well.
nadrux
Dec 30, 2024Tutor
thank you for your answer and in term of update/ stability is it better then the old 850 ? ( recent update)
- FURRYe38Dec 30, 2024Guru - Experienced User
I've not had the 860 series to test with, only the 850 series. I think the only difference was the WAN port, the 860 series has a 10Gb WAN port where the 850 has a 2.5Gb speed on the WAN port. I think everything else was the same. Something you can check out between each model spec sheet to see.
- CrimpOnDec 30, 2024Guru - Experienced User
I agree. The only significant difference appears to be incorporating a 10G WAN port on the 860 to replace the 2.5G WAN port on the 850. Both systems have the same Qualcomm IPQ8074A processor. Same RAM. Same storage.
https://www.netgear.com/images/datasheet/orbi/rbk852.pdf
https://www.downloads.netgear.com/files/GDC/RBR860S/RBR860S_TS.pdf
The 860 Product Data Sheet makes a vague reference to "new antenna design" on the 860. They do not look much different from the 850 antennas on the FCC submission internal photos:
https://fcc.report/FCC-ID/PY319200452/5159988
https://fcc.report/FCC-ID/PY322100556/5989864
Is it worth $300 to have a 10G WAN port?
- nadruxJan 02, 2025Tutor
thank you for your annswers guys. I still hesitate tho... the 850 is "old" and yet still expensive but could do the job but i dont know how many time.. the 960 worse in price im not sure and the 770 im afraid to try another model and having issues with it again (had to return it).... the 760 was reallyyy fine but didnt had the iot ssid...
