tylerwhite
May 08, 2024Aspirant
Orbi 960 -- disconnects, etc
I "upgraded" from an RBR50 with 3 satellites to a 960 with 3 satellites and it has been a terrible experience in virtually every way. Every new unit has been placed in the exact same location as the...
May 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can you draw up a floor layout of the home and indicate where the RBR and RBS are placed?
Building materials of this home?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
How are the Sonos speakers connected? wired with the base unit or all wireless? Sono has there own broadcast signal I believe.
Are you using the separate 6Ghz wifi network or is that disabled?
