disarray42
Aug 30, 2023Aspirant
Orbi 960 - How to determine wired backhaul speed
Hello! I I have a wired network with both Gigabit and 2.5Gbe ports... and I think I have my Orbi sats on the 2.5Gbe ports... but would like to verify what speed they are connected at. Is there a way ...
Aug 31, 2023Guru - Experienced User
Ya that's the only check on the RBR to see the connection rate between the RBR and RBS.
Can connect a non managed multi gig LAN switch in between to visually see the link rate. XS505M and GS110MX work great with the 9 series.
