colst03
Jun 10, 2022Tutor
Orbi 960 - Maximum distance (outdoor no walls
Hello, What is the maximum distance between 2 Orbi 960 satellites ? Outdoor , direct view, no walls. Does rain affect ? Is same between Master and Satellite? What about 60 meters ? What max spee...
Jun 10, 2022Guru - Experienced User
colst03 wrote:
Hello,
What is the maximum distance between 2 Orbi 960 satellites ? Outdoor , direct view, no walls. Could reach 60 feet or maybe more between two buildings.
Does rain affect ? YES. Orbi systems are INDOOR systems. Not designed for outdoor use.
What about 60 meters ? What max speed ? Look at data sheet to see connection rates.
Thanks in advance.
Stephane.
- colst03Jun 10, 2022TutorThanks for your quick answer and sorry if I was not clear enough.
Both satellites will be inside but the distance to cross will be outside 🙂
So will the connection be worse when it's raining ?
Distance between the 2 buildings is 200 feet (no walls only large windows)
Will it work ? What will be max speed (in that specific use)
Thanks in advance.
Stephane.- colst03Jun 10, 2022TutorHello,
Does a outdoor satellite exist for the Orbi 960 exist ?
What reference ?
Alternative solution? To crosse about 60 meters .
Thanks in advance.
Stephane.- FURRYe38Jun 10, 2022Guru - Experienced User
No outdoor RBS.
Best recommendation for that kind of distance would be CAT6A buried LAN cable.
