fredricr1
Apr 15, 2023Aspirant
Orbi 960 - needed outdoor extended range hello
I’ve got a 960 system (RBRE960 and RBSE960 - router and 2 satellites) in my home but I need coverage to reach a camera (2.4Ghz) a ways away outside. A satellite in the window facing that camera is qui...
- Apr 15, 2023☺️for the suggestion. As I said, not tech oriented. How will giving the extender 2.4 signal a different name/SSID force the camera to connect to it? Will this 2.4 band have a different password, like having a completely separate network aside from the 2.4ghz band on the mesh network? This is a Blink camera, if that matters.
CrimpOn
Apr 15, 2023Guru - Experienced User
Number 3. Outdoor rated WiFi extender. There are several brands on Amazon. Be sure to read the product information carefully. Even when search terms are specific, Amazon mixes all sorts of products together. Give the 2.4G signal it produces a different SSID than the primary system so that the camera will attempt to connect only to this access point.
fredricr1
- CrimpOnApr 15, 2023Guru - Experienced User
This is not a requirement, only a recommendation. When and device is set up and told to use WiFi "ABC" with a certain password, that is what it will connect to. (and nothing else) This will avoid situations we see so often on the forum when users ask, "why does my device connect to an access point with a worse signal?" Suppose this exterior WiFi extender power is interrupted and its signal disappears. If the camera is looking for the primary WiFi, it may attempt to latch onto the house unit and get a very poor signal.
This also avoids problems such as you arrive home and your smart phone connects to the first WiFi access point it sees (the extender) and hangs onto it after you walk inside because the extender is not a "satellite" and does not communicate with the inside system to support Fast Roaming.
