Retired_Member
Jan 30, 2025Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks
Hello all, I’ve been investigating the device disconnect issues that many users have reported on this forum. After extensive testing of various wireless settings, I believe I’ve identified the...
- Retired_MemberJul 29, 2025
I have now managed to get round to testing this, and I can confirm that "Firmware Version 7.2.7.15" has fixed this issue for me.
Retired_Member
Jan 31, 2025Hi CrimpOn
Thanks for the info regarding the hardware.
I observed this issue by connecting to each band separately, and saw that the disconnects were not happening on the 2.4GHz network but were happening on both the 5GHz and 6GHz networks, I then used a wifi scanner to monitor the bands when the issue happened and could see the bands would disappear at the time of disconnect.
Liam
Liam
Jan 31, 2025Guru - Experienced User
Had you seen this on v.21 as well?
