liamscor
Jan 30, 2025Luminary
Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks
Hello all, I’ve been investigating the device disconnect issues that many users have reported on this forum. After extensive testing of various wireless settings, I believe I’ve identified the...
- Jul 29, 2025
I have now managed to get round to testing this, and I can confirm that "Firmware Version 7.2.7.15" has fixed this issue for me.
Feb 11, 2025Guru - Experienced User
So good to hear channel 13 seems to work better for those in the EU region.
Hopefully this will help your system.
Are you still using lasted v7 FW or did you revert back to v6?
liamscor
Feb 12, 2025Luminary
Hi,
I'm currently still using firmware "7.2.6.31".
So far with the tweaks I have made everything seems ok now.
Liam
