Retired_Member
Jan 30, 2025Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks
Hello all, I’ve been investigating the device disconnect issues that many users have reported on this forum. After extensive testing of various wireless settings, I believe I’ve identified the...
- Retired_MemberJul 29, 2025
I have now managed to get round to testing this, and I can confirm that "Firmware Version 7.2.7.15" has fixed this issue for me.
Feb 23, 2025Guru - Experienced User
New FW is out:
Please update and check. May need a facory reset and setup from scratch to ensure a good take on the new FW and see if all works better for you.
Retired_Member
Jul 29, 2025I have now managed to get round to testing this, and I can confirm that "Firmware Version 7.2.7.15" has fixed this issue for me.
- FURRYe38Jul 29, 2025Guru - Experienced User
It it was just the application of the newer FW that resolved this for you then?
Correct, I manually applied the new firmware, and then factory reset and setup from scratch.
Ok, thanks for the details. Glad it's working.
Enjoy. 📡
