norbertsf
Jun 26, 2024Aspirant
Orbi 960, adding switch and network failure
Hi all, Info: Orbi 960 router and 2 satellites. Firmware 7.6.31_5.0.24 Cat 5e cables throughout. Netgear GS308v3 unmanaged switches Motorola MB8611 Cable modem I have factory reset every...
- Jul 01, 2024
Guys thanks for the help on this.
So 2 things.
1. I switched out cable connecting router to the Netgear 16 Port switch, and am now getting 945Mbps, Network solid (wired and wireless).
2. I continued attaching ethernet devices to the switch and apparently my Airport Express 1st Gen was the cause of the network failure. I am going to have to figure out how to set this up or give up on it. ( I used to use it for Apple Airplay - music streaming). It may be more trouble than it is worth.
norbertsf
Jul 01, 2024Aspirant
So 2 things.
Jul 01, 2024Guru - Experienced User
Glad that was all.
I haven't used my AE in a while. Not sure if it still even works. Used for same thing. Music streaming. Only thing I did on mine back then was set it for a static IP address out side of the default DHCP IP address pool. I use .100 to .150 for my needs. Something to try.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
