CJT_OIB
Aug 10, 2024Follower
Orbi 960 and Snap AV
I am trying to connect an Orbi 960 to a Surfborad SB8200 that has two ethernet ports. I am using one port to connect to a Snap AV network that uses Control4 system. I am trying to use the other por...
CrimpOn
Aug 10, 2024Guru - Experienced User
Your observation is correct. The Surfboard SB8200 cable modem connects to one device, the first one that is connected.
You have to choose:
- Connect the Snap and then connect the Orbi router to the Snap, or
- Connect the Orbi and connect the Snap to the Orbi.
