CJT_OIB
Aug 10, 2024Follower
Orbi 960 and Snap AV
I am trying to connect an Orbi 960 to a Surfborad SB8200 that has two ethernet ports. I am using one port to connect to a Snap AV network that uses Control4 system. I am trying to use the other por...
Aug 12, 2024Guru - Experienced User
Like CrimpOn, the sb8200 will only connect 1 device. The reason why is the ISP only assigns 1 public IP address.
You might be able to call your ISP and see if you can pay for a 2nd IP address (not very likely), switch to a business class line that supports those features, or you can just go modem->router->snap AV
