jmccabeVA
Mar 26, 2025Guide
Orbi 960 and Wifi Calling issues
All, I have the Orbi 960 system. Router and two satellites. This solution is in AP mode. Router connects to my .97 network which is VLAN 20 in my house as it's WAN gateway to my pfSENSE router/Fir...
jmccabeVA
May 29, 2025Guide
I did have some QOS on the managed switches. I turned that to low priority - lowest level. On pfSense (my gateway and FW that does the inter-vlan routing as well, has a setting in System/Advanced/Firewall&NAT/ Firewall Optimization Optoins. Other threads said to set this from normal to Conservative. Also under State Timeouts in same location to change UDP Multiple from 60 to 900. Made those changes. Also pfsense was upgraded from 2.72. to 2.80 CE (community Edition - which I run).
Same issues this morning.
is there any case where the Obi's could be too close?
