jmccabeVA
Mar 26, 2025Guide
Orbi 960 and Wifi Calling issues
All, I have the Orbi 960 system. Router and two satellites. This solution is in AP mode. Router connects to my .97 network which is VLAN 20 in my house as it's WAN gateway to my pfSENSE router/Fir...
May 29, 2025Guru - Experienced User
What are the brand and model# of these manages switches?
Do you have any of the RBS connected to these switches? Or are they wireless connected?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Is SIP ALG enabled or disabled on the RBR?
I'd try the Orbi system connected to the Verizon FIOS ONT with out any PFsense or managed switches in the mix to see if the issue continues
