EnvisionIT
Sep 22, 2022Follower
Orbi 960 AP mode question on hooking up Sat
Have 4 Sat units and the base router. I have been running in Router mode. Modem = Router = Switch = Orbi Router (wan port gets dhcp from main router). This basically works but all my devices a...
ekhalil
Sep 23, 2022Master
Ok, so I assume that your ISP router has default 192.168.1.x IP range and when you connect Orbi to that router then Orbi will switch to 10.0.0.x IP range to avoid conflict. You mentioned that Orbi worked well when it was in router mode, was the ISP router set for DMZ forwarding, bridged, passthrough? Was DHCP disabled on the ISP router? If not, were your devices getting IP addresses from the 10.0.0.x or from the 192.168.1.x IP ranges?
Now you switched Orbi into AP mode, so the ISP router will be the main router, so you should remove the previous settings like bridging, passthrough or DMZ forwarding if any was done. Also you need to make sure the ISP router will provide DHCP addresses.
If this is correctly set then you will have all your satellites and devices working in AP mode as in roter mode.
- KevinLiTSep 23, 2022NETGEAR Moderator
Hello EnvisionIT,
Welcome to the NETGEAR Community!
I understand that you are not able to connect your Orbi 960 to the RBS in AP mode. Please disconnect the Orbi satellites from the hub leaving the Orbi 960 plugged in. Then connect the satellites one at a time to the hub, then press the sync button on the back of the satellite. Please ensure that each satellite is able to successfully connect before adding additional satellites to the hub.
Let me know if this helps!
Best,
Kevin
Community Team
