Nobber1066
Jul 31, 2023Aspirant
Orbi 960 Black & IP Camera problem
Hello just moved over to Orbi 960 from BT Whole Home I have turned off my BT Whole home Mesh but my cameras wont connect to Blueiris I have setup the 2.4Ghz wifi and they are showing as connected t...
- Jul 31, 2023
I tried option 2 first but that didnt work, so I have set the Orbi to AP mode and seems to be working ok now, but I cant manage my network via the App
so looking for suggestions for a router to replace my BT SMART Hub 2, thanks for your help
Jul 31, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Contact the Mfr of the cameras for additional help and support information regarding there product.
- Nobber1066Jul 31, 2023Aspirant
Thank you
- FURRYe38Jul 31, 2023Guru - Experienced User
đ
Hello Can some advise on a new router to replace my BT Smart hub 2 please
I cant turn on bridge mode
Try option #2...
Something to ask the ISP about if there equipment can be replaced by something else. Like the RBR maybe. They will know.
