Nobber1066
Jul 31, 2023Aspirant
Orbi 960 Black & IP Camera problem
Hello just moved over to Orbi 960 from BT Whole Home I have turned off my BT Whole home Mesh but my cameras wont connect to Blueiris I have setup the 2.4Ghz wifi and they are showing as connected t...
- Jul 31, 2023
I tried option 2 first but that didnt work, so I have set the Orbi to AP mode and seems to be working ok now, but I cant manage my network via the App
so looking for suggestions for a router to replace my BT SMART Hub 2, thanks for your help
Nobber1066
Thank you
Jul 31, 2023Guru - Experienced User
- Nobber1066Jul 31, 2023Aspirant
- FURRYe38Jul 31, 2023Guru - Experienced User
Something to ask the ISP about if there equipment can be replaced by something else. They may have requirements.
