c3polt
Jun 23, 2024Aspirant
Orbi 960 Block Services Not Working
I have setup a Block Services rule on my Orbi 960 and it does not work. I have reserved a specific IP address for my robot vacuum (192.168.1.251). I then went to Advanced -> Block Services turned ...
- Jul 06, 2024
After going back and forth with support a few times, I received this as a response:
"Thank you for your time and patience. According to the engineering team, the block services in the Web GUI will only block HTTP sites and services. They recommend using the Smart Parental Control instead."Unfortunately, Netgear charges a monthly fee to use the “Smart Parental Controls.” In my opinion, this is a highly anti-consumer practice, especially considering that these are fairly basic router capabilities on a product that costs over $1000.
Jun 24, 2024Guru - Experienced User
- c3poltJun 24, 2024AspirantThe latest firmware V7.2.6.31
I’m not sure what the modem is, it sits outside my unit- FURRYe38Jun 24, 2024Guru - Experienced User
This happen while using a different browser?
Does the modem have a sticker with any information on it?
- c3poltJun 24, 2024AspirantYes, I’ve tried with both Chrome and Safari.
I don’t have access to the modem, I live in an apartment where the modems sit in a centralized room we don’t have access to.
I’ve tried one factory reset, no change.
