RajjyP
Feb 26, 2023Aspirant
Orbi 960 Can someone give me a step by step on what to do to accomplish this
Can someone give me a step by step on what to do to accomplish this?
Mikey94025
Feb 26, 2023Hero
What the OP describes is not normal behavior for the Orbi. Power cycling the Orbi router and/or satellites should still result in a working system. My Orbi 9-series has never behaved as described and I do not need to re-sync my satellites after a power interruption.
If the problem is that the satellites cannot get a DHCP address after power interruption then we can start by investigating DHCP settings, reserved addresses for the satellites, etc. Is the Orbi in router mode or in AP mode (the Ziply modem may be a router too: https://ziplyfiber.com/wifi-6). If the Orbi is in router mode and the Ziply is also routing, then try removing Double NAT first.
- RajjyPFeb 27, 2023Aspirant
So I have an ATT fiber modem/router but the routing is turned off so the only thing connected to it is my orbi system. Do I still need to have the orbi in access point mode? It worked fine initially without me doing that.
