WiFiplease
Dec 24, 2023Aspirant
Orbi 960 disconnects
Having issues with my Orbi 960. Disconnects at least once a day and have to unplug and plug back in to work again. Tried factory restore many times and still same issue. Internet provider confirmed everything to be good in their side. Firmware is 7.2.6.21. Any beta firmware or recommendations.
1 Reply
Does the front LED turn on RED when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the size of your home? Sq Ft?What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Just took my 960 off line since being up for weeks. Have never seen this issue on v7 FW. Went thru extensive testing. Not all issues are FW released FYI.
