Ruegs
May 22, 2023Tutor
ORBI 960 Ethernet Backhaul Status Out of Sync
I'm running an ORBI 960 with two satellites connected to my LAN via Ethernet. I've had to replace the router due to a power surge from my local utility which damaged my original 960. Everything is wo...
Ruegs
May 26, 2023Tutor
So, the current status is unchanged. I've done the following:
1) I've removed both RBS units, factory reset them, added them back (using a wireless connection with the RBS and RBR in the same room) - still no sync. Although it showed good for a few seconds before reverting to Out of Sync. After connecting them via Ethernet, still no sync.
2) I had two unused RBS units (don't ask), factory reset them (just to make sure), added them to the system (using a wireless connection with the RBS and RBR in the same room) - still no sync. Although, again, it showed good for a few seconds before reverting to Out of Sync. After connecting them via Ethernet, still no sync.
Since my network is working and my 60+ devices are all connected and recognized in my automation apps, I'm beginning to think I'm chasing ghosts. The app and router web page are not accurate representations of what is going on with the network but if I need to see what is going on at the RBS level, I can just go their web pages. I might try Netgear support but life is short.
Straq
May 30, 2023NETGEAR Expert
Hello,
My main concern is #2. The fact the even wireless it appear out of sync is not a good sign. There is a probability that maybe going from 192.x.x.x to 10.x.x.x might have caused to go out of sync.
If you have the time, can you also factory reset router plus satellites, start from fresh. Then after you onboard on Orbi APP or on 192.168.1.1, wait about 5 minutes. All wireless and satellites in same room as router.
After this, check if the satellites are in sync. If they are great! If they are not, we have an issue.
If it is in sync, proceed to change to 10.x.x.x and wait 5 minutes. Check again if the satellites are in sync. If they are not then 10.x.x.x change might be the issue and we will look into this issue. If it is sync, might had been a sequencing issue of how things are onboarded and will also need to look into this.
