MikeArmadillos
Nov 13, 2022Aspirant
Orbi 960 IoT Issues
Hi All, I have an Orbi 960, 1 router, 2 satellights, and I have been having issues with the IoT network, Item's disconnecting, up until now a router reboot would solve the issue, now the IoT ne...
Nov 13, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- MikeArmadillosNov 13, 2022Aspirant
HI, FURRYe38,
thanks for helping out NG tech are now sending a replacement router, as it’s broadcasting IoT intermittently, but the out 2 networks are ok, it may also be that one safelight is not broadcasting 2.4ghz but that’s the next step, after this post i did some investigations and found it i could get IoT now and again next to the router and the other safelight.
As for info request each unit is about 30 meters apart
as for firmware it was the latest version the rolled back 2 versions
also Chanel’s we have tried various
as for other WiFi we see a couple of networks at different points of the house
ISP Virgin Media with super hub 3 but its in modem only mode
have tried several resets
will update when i get the replacement router
thanks again
- FURRYe38Nov 13, 2022Guru - Experienced User
Ok sounds good.
30 meters maybe a bit too far apart. 12-15 Meters maybe a better starting point.
