SokarNox
Feb 20, 2024Aspirant
Orbi 960 location services not working
Hello, my router is blocking location services. Example, can’t login to ChatGPT because I’m not in a supported region (I live in the USA). I try to use my Sonic app on my phone, my location is not sup...
- Feb 25, 2024
I got it fixed! I had a BestBuy 2 year warranty, I took it in and they replaced the Orbi, and now it's working fine! All firmware updated, This is 100% a router defect!
CrimpOn
Feb 20, 2024Guru - Experienced User
could you post a screen shot of the error message?
Does this system have Bitdefender Armor or Smart Parental Controls (SPC) enabled?
SokarNox
No VPN, Armor Security is on (don’t know how to turn it off) but it also was failing before I enabled it. No SPC
- SokarNoxFeb 20, 2024AspirantAnother image.
- CrimpOnFeb 20, 2024Guru - Experienced User
My impression is that Armor can be turned off with the Orbi app. (I have never enabled Armor, and thus have no personal experience. Once my lizard brain saw, "Free Trial." it went into "and then they want money" so the cheapo in me said, "No thanks."
Could you take a minute to verify the Time Setting on this Orbi system? This is a setting on the web interface, Advanced Tab, Administration Menu... NTP Settings.
Thanks for mentioning "no VPN". VPN is often used to manipulate geographical location.
Internet search turns up a number of discussions of this topic:
https://community.openai.com/t/cannot-access-chatgpt-no-matter-what-attempts-i-make/44399
https://www.youtube.com/watch?v=vunKWNLLABk
I liked the advice to delete browser cache (especially the way he pronounced "cach-aye") or to try a different browser.
There was a post on the forum where the ISP reported that the user public IP address was in the wrong state, which resulted in being unable to stream a sports event because it was restricted geographically.
It might be entertaining to contact the Internet Service Provider (ISP) and ask if other customers have reported this problem.
- SokarNoxFeb 21, 2024AspirantTime Setting are updated. Was set to UTC. See attachment.
I have tried different browsers, devices, incognito browser, tablets… fails on all devices.
I have called ISP, they are ones that suggested I plug the modem directly into my computer and then try (which I did, and then everything works) so that narrows it down to the router.- schumakuFeb 21, 2024Guru - Experienced User
Here again, your router does not know about location services - at all.
When using ChatGPU from your mobile (iOS phone from the screenshots), I don't know how you are able connect your iPhone direct to your Modem and compare...
To many players attempting to "enhance" the users "privacy" in yoiur data path. The obvious first point is your iPhone. Ok, you said "no VPN" ... what about the iCloud Privat-Relay for example?, It's much to easy to enable Content & Privacy Restrictions without recognizing.
Nothing, absolutely -nothing- on the normally operating NAT router like your Orbi 960 does block the location services. The router does not even know what a location service is.
- CrimpOnFeb 22, 2024Guru - Experienced User
SokarNox wrote:
No VPN, Armor Security is on (don’t know how to turn it off) but it also was failing before I enabled it. No SPCIs the Armor on this Orbi the "free trial" or a paid subscription?
- SokarNoxFeb 22, 2024Aspirant
It is a paid subscription, but it was not working before I paid for the subscription. I thought maybe stuff stopped working because I was not paying for the service, so I bought it. But like I said, it was already not working before I bought the paid subscription. It was just disabled.
- FURRYe38Feb 22, 2024Guru - Experienced User
Can you do the following with Orbi RBR unit?
Factory reset the router:
Reboot the modem then connect the RBR960.
Walk thru the setup wizard with a wired PC and web browser and setup from scratch:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Setup with limited changes just to see if this helps.
Let us know if this changes anything with the locations services.
