ktd2104
Oct 01, 2022Aspirant
ORBI 960 no 2.4GHZ internet.
I have a system of 3 Satellites and 1 router of ORBI 960, FW: V6.0.3.85_3.1.15. I tried to turn on the IOT network with 2.4ghz only. The system broadcast the SSID, and I can connect to it, however, w...
ktd2104
Oct 05, 2022Aspirant
=> it's the Xfinity Gateway Gen 3
If you turn OFF the RBS, does the IoT network with with the RBR alone?
=> There is no 2.4Ghz internet in general, not only for the IOT. I put 2.4Ghz only for the IOT to test, and it does not have any internet. The main internet and guest internet work perfectly with 5.0Ghz, but still no 2.4Ghz, all devices require 2.4Ghz can not connect to any of the SSID.
When I first set up with only 1 RBR, No RBS, it has 2.4Ghz, however, it's at 0.5-1.0 Mbps, it's almost nothing.
Does the devices connect if you set 2.4 and 5Ghz enabled on the IoT network?
=> When I set 2.4Ghz and 5Ghz combine then IOT just like regular SSID and Guest wifi, it works only with 5.0 devices, not 2.4 devices => meaning still no 2.4 Ghz broadcasting.
Oct 05, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If after turning off any WIFI radios on the ISP modem and powering OFF the Orbi system for 1 minute then back on and doing a factory reset on the RBR and setup from scratch, does not bring back 2.4Ghz connectivity, you'll need to contact NG support and open a support ticket: https://my.netgear.com/support/contact.aspx
