Will307's avatar
Will307
Tutor
Mar 30, 2023
Orbi 960 Placement
I have the Orbi 960 and two Sats.  My house is 3200 sq foot built in 1996 (all dry wall no concrete).  I have had connectivity issues and speed issues for months.  Recently,  I decided to unplug both of my satellites and I am finding this more stable but still not what I want in terms of coverage.
My router is pretty much dead center of my home.  Before I unplugged my Sats one was ~30 feet upstairs and the other ~30 feet downstairs.
Assuming my issue is too much overlap of all 3 boxes.....seems my choices may be
1) Reduce the transmission power of my router to 25% and leave the sats where they are
2) Move my Router to one corner of my home and only use one Sat and move this to the opposite corner (up 2 floors).
Any help here would be appreciated.....perhaps there is another choice.
  •  I know.  I read that.  I deleted my App and reinstalled it.  So far I cant find an example but I am certain it was like this.  I'll screen shot an example if I can find one.  Some devices that are connected do not show link-speed now.
  • CrimpOn's avatar
    CrimpOn
    Most users tend to place the base unit (RBRE960) where the Internet Service Provider (ISP) device is.  If you are able to relocate that device to a radically different place in the building, you are one of the "lucky few".
    There is certainly no harm in reducing the Transmit Power to see what effect it has. (Not much effort required, either.)
    It might be helpful to have a description of what sort of issues you were (and are) facing.
    • Will307's avatar
      Will307
      Tutor
      I have several Roku TVs.  They often lose connection or slow down dramatically.  I have Wifi cameras inside and outside -- same issue. My kids have tablets and when they move around (downstairs living room to upstars bedroom) often it just hangs until i re-boot it.
      I can probably move my Router and Modem to my Garage where the cable comes into the house.  This is one absolute corner -- let's say South West......North East (2 floors up) and I then put a Satellite.  I need covered to extend outside for my outdoor Wifi cameras.
      • CrimpOn's avatar
        CrimpOn
        "it" as in:
        • The tablet hangs until the user turns WiFi off and back on?
        • The tablet hangs until the entire WiFi system is powered off and back on?
