GM_FFX's avatar
GM_FFX
Guide
Sep 18, 2022
ORBI 960 (RBRE960) WAN on 1Gb LAN port?
Is it possible to use one of the 1Gb port as WAN and turn the 10Gb WAN into a LAN port?
1 Reply
  • Not exactly! 🙂 The GB ports in the RBRE960 are meant for the following:
    • 10 Gbit Ethernet port for Internet -  WAN port with support of up to 10 Gbps Internet speeds. This can't be used for LAN except when you have Orbi in AP mode.
    • 2.5 Gbps Ethernet port for wired connections -Multi-gig Ethernet port for wired connection to network storage, LAN gaming, in-home media streaming, or use it to set up a wired multi-gig connection between the router and satellites with structured Ethernet wiring in your home.
