Steve1019
Oct 29, 2021Guide
Orbi 960 Series Throughput
I'm a bit confused by an aspect of the new Orbi 6E routers. That is, if the 6GHz frequency has so much more throughput than the 5GHZ frequency (twice as much) and the second 5GHz band that is the one...
Oct 30, 2021Guru - Experienced User
plemans is correct. 6Ghz is even higher frequency and is more effected by building materials and such. The 6Ghz is front haul only on the 9 series Orbi. The wifi backhaul is still on 5Ghz at 2400Mpbs.
Also honesly, I've never been able to get a device to connect at 4800Mpbs. I really wish router mfrs would not market that speed. It take near perfect conditions at at close range and GOOD FW to be able to see 4800Mbps in a test environement. Out here in the field, I've only seen around 3200Mpbs to maybe 3800Mpbs between two devices at close range on 5Ghz. Same goes for 6Ghz. And for every day use, 4800Mbps will never been seen for the average user. 2400Mpbs seems to be the sweet spot speed for wireless backhaul.
- FURRYe38Nov 01, 2021Guru - Experienced User
- Steve1019Nov 03, 2021Guide
So what is being said then is that a client device connected to an Orbi 6E satellite unit on 6GHz could only ever exceed 2400Mbps if that Orbi satellite unit was connected to the main Orbi unit via hardwire Ethernet backhaul. Of course I understand that two devices connected to each other on 6GHz via the same satellite unit could exceed 2400Mbps even if backhaul was on 5GHz and limited to 2400Mbps because backhaul wouldn't be involved in that circumstance. Am I understanding this correctly?
I take part of that back. Wired backhaul appears to be limited to 2500Mbps, so the whole theoretical 4800Mbps capability on 6GHz seems to be completely limited to communication between devices connected to the same mesh unit.
- FURRYe38Nov 03, 2021Guru - Experienced User
Yes.
