Dirien
Dec 31, 2024Aspirant
Orbi 960 slow & intermittent connection
Hello, I have been using an Orbi 960 system running V7.2.6.31_5.0.24 with accompanying RBSE 960 satellites for a year now. When I first purchased the system, I noticed a number of devices were havi...
Dec 31, 2024Guru - Experienced User
You might downgrade the system, RBS first then RBR lastly to v.21 version of FW. There has been many posts regarding bad behaviors with v.31. I currently have my 963 series online now and working well. On v.21 FW though.
If you downgrade, you'll need to factorry reset and setup from scratch. Follow this PDF process: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2356834/highlight/true#M52575
Dirien
Thanks for the suggestion! Has this particular firmware been out for over a year? I’ve been having issues since August 2023.
- FURRYe38Dec 31, 2024Guru - Experienced User
Yes. It's most stable to date.
Lets get the system downgraded and factory reset then go from there. We can troubleshoot issues seen after that.
- DirienJan 02, 2025Aspirant
I was able to factory reset & downgrade firmware of Router + Satellites to V7.2.6.21. No difference in performance.
- FURRYe38Jan 02, 2025Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?Got a layout floor drawing of where the RBR and RBS are placed so we can see how the home and placement is configured?
