Dirien
Dec 31, 2024Aspirant
Orbi 960 slow & intermittent connection
Hello, I have been using an Orbi 960 system running V7.2.6.31_5.0.24 with accompanying RBSE 960 satellites for a year now. When I first purchased the system, I noticed a number of devices were havi...
Dirien
Thanks for the suggestion! Has this particular firmware been out for over a year? I’ve been having issues since August 2023.
Dec 31, 2024Guru - Experienced User
Yes. It's most stable to date.
Lets get the system downgraded and factory reset then go from there. We can troubleshoot issues seen after that.
- DirienJan 02, 2025Aspirant
I was able to factory reset & downgrade firmware of Router + Satellites to V7.2.6.21. No difference in performance.
- FURRYe38Jan 02, 2025Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?Got a layout floor drawing of where the RBR and RBS are placed so we can see how the home and placement is configured?
All of the devices are more than 30 feet away from each other with several walls and floors in between. Backhaul connection is wireless and showing "Good". My layout is very similar to the one in the large multistory home with an additional router on the top floor that covers the areas where the basement and family room systems can't quite reach with good speeds.
Current Layout: 5000 Sq Ft House
Top Floor - 1 Satellite in my wife's office
Main Floor - 1 Router connected to xFi Gateway located in Family Room
Basement - 1 Satellite located in TheatreChannels - I don't have many WiFi neighbors overlapping with me. This is based on an analysis of the networks using a WiFi Analyzer on Windows. I originally had auto, but opted to try some manually selected channels after viewing the WiFi tool:
2.4 GHz - 06
5 GHz - 48
6 GHz - 69
