Dramsey
Dec 05, 2023Aspirant
Orbi 960 solid blue light when connected to modem
I’m trying to connect my new Orbi 960 to my cable modem. I’ve unplugged the modem and let it sit for a minute before plugging it back in; then I connected the 960 and plugged it in. The white light p...
CrimpOn
Dec 06, 2023Guru - Experienced User
FURRYe38 wrote:
For the RBR there is now BLUE front LED. RBR only supports Blinking WHITE, AMBER and PINK. OFF means normal good connection with the ISP modem or ONT and isp services.
Is this a typo? "now" instead of "no"?
There never was a Blue light? not even for three minutes?
RBR is the only one that doesn't turn on BLUE. RBS do.
