edski2023
Aug 25, 2023Aspirant
ORBI 960 speeds 1/2 of modem speeds
Just converted old ORBI system to new 960 mesh w/ three satellites. Using app, it shows speeds from modem at +/- 950mbs. Top wifi signal (anywhere in house) is 550mbs. Why tout monster capabiliti...
edski2023
Please explain 2x2 vs 4x4. I am using computers (older iMac and newer MacBook Air, plus newer iPhones (Wifi 6 capable).
CrimpOn
Aug 25, 2023Guru - Experienced User
Theoretical vs. actual WiFi performance is a complicated subject. Internet searches will provide links to dozens of informative articles, such as this one:
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
The bottom line is that those wildly inflated promises* about WiFi are just that: wildly inflated. In actual practice, an older WiFi device that is located just a couple of feet from the access point will be lucky to achieve 400Mbps. A modern WiFi6 device will perform better, and is also affected by distance.
* can anyone in their wildest dreams imagine a marketing department choosing to highlight
- What's is most likely to happen in the real world, over
- The absolute best case scenario under ideal conditions?
