woodsmit
Oct 02, 2022Tutor
Orbi 960 system and 850 satellites - Confirmed working
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 96...
Oct 02, 2022Guru - Experienced User
Really...what FW version are you using on the 8 and 9 series?
Please post a screen capture of the 9 series connected clients page...And what was the process to get them synced?
woodsmit
Oct 02, 2022Tutor
Sure, see attached (Scrubbed out Mac addresses etc).
960's running v6.0.3.85_3.1.15 and 950's running V4.6.9.11
Process was like normal: I hard reset the 850s with a needle, initiated the satellite pairing sequence on the orbi web interface, plugged in the 850s again to power, when prompted I hit the sync button on the 850 and then it relatively quickly indicated it found the satellite and paired.
Once paired, I moved one to another room wireless backhaul and the other I attached to ethernet for backhaul, which didn't require any tweaks to config. Just spun right up.
- FURRYe38Oct 02, 2022Guru - Experienced User
Wow, confirmed:
Can access the RBS web page.
Interesting it seems connected at WPA3:
Wondering if this would be backwards compatible with non WPA3 devices. Mixed WPA2 and WPA3 is set on the RBRE960.
