woodsmit
Oct 02, 2022Tutor
Orbi 960 system and 850 satellites - Confirmed working
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 96...
Oct 03, 2022Guru - Experienced User
Can you post a screen capture of the statistic page from the RBR while you have the RBS850 connected to the system?
woodsmit wrote:
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 960 router and the other is using wireless backhaul. Both are working fine.
- woodsmitOct 04, 2022Tutor
Which specific page, not sure which one is the statistics page
