woodsmit
Oct 02, 2022Tutor
Orbi 960 system and 850 satellites - Confirmed working
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 96...
Oct 03, 2022Guru - Experienced User
Can you post a screen capture of the statistic page from the RBR while you have the RBS850 connected to the system?
woodsmit wrote:
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 960 router and the other is using wireless backhaul. Both are working fine.
woodsmit
Oct 04, 2022Tutor
Which specific page, not sure which one is the statistics page
