Dan007
May 11, 2024Aspirant
Orbi 960 system dropps 2.4Ghz devices frequently
I have an Orbi960 system that constantly drops certain 2.4Ghz devices frequently (~1 time a week) until rebooting the whole system (these include Level lock connect wifi devices, Awair air quality se...
May 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router đĄ and satellite(s)đ°ïž? 30 feet or more is recommended in between RBR đĄ and RBS đ°ïž to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ââđ°
Distanced between the RBR/RBS and these 2.4Ghz devices?
Does this happen with the RBS turned OFF?
Does this happend with the devices connected to the separate IoT network?
What channel configurations are currently set on the router?
Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
