lisakc
Sep 28, 2022Tutor
Orbi 960 Wifi Extender
Just learned we need a Wifi Extender for our new Orbi 960, AXE 11000, wifi 6E system to connect to an outside solar battery. Is there any alternative to a $600 extra satellite? Many thanks to all in ...
Sep 28, 2022Guru - Experienced User
No.
If you can find a RBS50Yv2 outdoor unit that has Extender mode FW loaded on it you could use this to connect out side.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
How far is this device from the nearest RBR or RBS in the home?
