jabenedicic
Apr 06, 2023Tutor
Orbi 960 Wired Backhaul Requirements
Good morning, does anyone know if there are any specific requirements for wired backhaul on these units? On my previous XS508M switches they would connect wired without any issues. Since changing t...
jabenedicic
Apr 06, 2023Tutor
It’s all Cat6 cabling or fibre between my switches.
I can’t switch anything back to the XS series as Netgear took them back when they swapped them out for these MS series. The XS devices had some strange issues where some ports would just randomly stop forwarding any traffic at all, engineering looked at it for a while and just replaced all my switches for me.
I use the MS series in Insight managed mode so there really are only a handful of settings you can use. They are really basic.
I’ll try open a support case as there’s something that just doesn’t play nicely. May try an Orbi Pro with Insight management as well, see if that works.
Apr 06, 2023Guru - Experienced User
Interesting, I did find one odd with with my two switches and Apple TV:
Changing the cabling around on the ports seems to help for me.
Ya, have no experience with the MS series switches. So there maybe some issues seen here with this if IGMP and or if Green Ethernet features are enabled. Saw this on other branded managed switches and users posted that disabling these helped get RBS ethernet connected correctly to the RBR. If your in NG support, I would bring this up to them about any known issues between MS switches and Orbi AX series systems.
