NickUrso
Aug 22, 2023Aspirant
Orbi 960
Hello, we are installing fiber at our locations and the provider is asking does the router use single or mutli-mode fiber on the 10G port? thanks
Aug 22, 2023Guru - Experienced User
The 960 doesn't support Fiber optical input connections, only RJ45 10Gb ethernet cable port jack.
The ISP should provide a ONT that converts there Fiber optics to ethernet connection.
