THATSMYSTUFF
Dec 07, 2023Aspirant
ORBI 960B MESH SYSTEM
I HAVE HAD THE ORBI 960B FOR A YEAR NOW BUT ... SINCE INSTALLATION BY A TECH THE ORBI SYSTEM TO NOT WORK DIRECTLY WITH OUR STARLINK SYSTEM. AFTER A COUPLE OF HOURS AND NETGEAR TECH SUPPORT THE TECH W...
Dec 07, 2023Guru - Experienced User
SO USE OF CAPS IS NOT NEEDED. WE CAN HEAR YOU JUST FINE. NO NEED TO YELL.
Others in the community posted about putting a simple non managed 1Gb LAN switch in between the StarLink modem and the Orbi RBR unit. Also recommend using CAT6A STP cabling as well between them. https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Orbi-6e-cannot-connect-to-Starlink/m-p/2231158/highlight/true#M33998
- THATSMYSTUFFDec 07, 2023Aspirant
Nice,
My bad 🙂
Blind Mellon Chitlin Out
