atiq020's avatar
atiq020
ORBI 960E NOT SHOWING WIFI6E ON MY LAPTOP
I change my windows 10 home addition  wifi adapter to intel wifi 6e ax210 ALL Driver are upto date and Orbi ENABLE wifi 6E. mode. but still not showing on my laptop.  my product details are using W...
  • TC_in_Montana's avatar
    Aug 14, 2022
    atiq020
    I have never seen anything definitive that Windows ever put out an update that successfully supported WiFi 6E under WIndows 10.   There were lots of "We will support on this update and then we will support on this next update".   I've seen other comments from Windows that says that you need to be on Windows 11 to have native support for WiFi 6E.
    There were some methods using one particular driver set and some registry tweaks that kind of enabled WiFi 6E support but that was the towards the end of last year I believe.  The only device I have with a WiFi 6E card even had some issues with that method.
    I finally updated the one PC with the WiFi 6E card to Windows 11  (even though it truly didn't support Windows 11 due to one requirement) and have full WiFi 6E  support  and have had zero issues with running Windows 11 on the PC that did not meet 100% of the requirements.
