atiq020
Aug 14, 2022Aspirant
ORBI 960E NOT SHOWING WIFI6E ON MY LAPTOP
I change my windows 10 home addition wifi adapter to intel wifi 6e ax210 ALL Driver are upto date and Orbi ENABLE wifi 6E. mode. but still not showing on my laptop. my product details are using W...
- Aug 14, 2022
I have never seen anything definitive that Windows ever put out an update that successfully supported WiFi 6E under WIndows 10. There were lots of "We will support on this update and then we will support on this next update". I've seen other comments from Windows that says that you need to be on Windows 11 to have native support for WiFi 6E.
There were some methods using one particular driver set and some registry tweaks that kind of enabled WiFi 6E support but that was the towards the end of last year I believe. The only device I have with a WiFi 6E card even had some issues with that method.
I finally updated the one PC with the WiFi 6E card to Windows 11 (even though it truly didn't support Windows 11 due to one requirement) and have full WiFi 6E support and have had zero issues with running Windows 11 on the PC that did not meet 100% of the requirements.
CrimpOn
Aug 14, 2022Guru - Experienced User
atiq020 wrote:
All Drivers are up to date
I do not have a computer capable of WiFi6E, and thus lack the personal experience described by TC_in_Montana . Would you please consider verifying that the up to date device driver supports WiFi6E by navigating to the Control Panel, Network and Sharing Center. Select Change Device Settings (left side of screen). Then right click on the WiFi adapter, select Properties, select Configure. Then select the Advanced Tab. Here's what my old desktop WiFi shows:
My newer laptop has a lot more entries on the Advanced tab. Does yours have an entry for WiFi6E?
atiq020
sorry to tell in my question, i already did yours steps. but when i chose ax mode in advanced its not stored goes back to previous settings
- CrimpOnAug 14, 2022Guru - Experienced User
The Intel web site says that Windows 11 is required for the Wi-Fi 6E AX210 (Gig+) adapter to use the 6G wireless band:
https://www.intel.com/content/www/us/en/support/articles/000059385/wireless.html
Also, there is often confusion between WiFi6 (which is 802.11ax in the 5GHz wireless band) and WiFi6E (which is in the 6GHz wireless band).
I would hope that the Advanced settings for the Intel AX210 would include a setting that specifically mentions 6E.
Windows 10 certainly supports 802.11ax, so I have no idea what would cause the Advanced setting to behave that way.
- FURRYe38Aug 14, 2022Guru - Experienced User
"WIFI INTEL ADAPTR AX210 6E all drivers up to date" This is a WiFi 6E supporting adapter. I have this one on one of my PCs. It does work for both Windows 10 and 11 though there was some info out there that MS didn't want to support 6E in Windows 10. Mines currently running on Windows 11.
Thanks for the screen capture. Will be interesting to see if the OP's system displays the same information.
Could you please report the driver version number as well? (To see if his matches.)
