atiq020
Aug 14, 2022Aspirant
ORBI 960E NOT SHOWING WIFI6E ON MY LAPTOP
I change my windows 10 home addition wifi adapter to intel wifi 6e ax210 ALL Driver are upto date and Orbi ENABLE wifi 6E. mode. but still not showing on my laptop. my product details are using W...
- Aug 14, 2022
I have never seen anything definitive that Windows ever put out an update that successfully supported WiFi 6E under WIndows 10. There were lots of "We will support on this update and then we will support on this next update". I've seen other comments from Windows that says that you need to be on Windows 11 to have native support for WiFi 6E.
There were some methods using one particular driver set and some registry tweaks that kind of enabled WiFi 6E support but that was the towards the end of last year I believe. The only device I have with a WiFi 6E card even had some issues with that method.
I finally updated the one PC with the WiFi 6E card to Windows 11 (even though it truly didn't support Windows 11 due to one requirement) and have full WiFi 6E support and have had zero issues with running Windows 11 on the PC that did not meet 100% of the requirements.
Aug 14, 2022Guru - Experienced User
"WIFI INTEL ADAPTR AX210 6E all drivers up to date" This is a WiFi 6E supporting adapter. I have this one on one of my PCs. It does work for both Windows 10 and 11 though there was some info out there that MS didn't want to support 6E in Windows 10. Mines currently running on Windows 11.
CrimpOn
Thanks for the screen capture. Will be interesting to see if the OP's system displays the same information.
Could you please report the driver version number as well? (To see if his matches.)
- FURRYe38Aug 15, 2022Guru - Experienced User
This what I have currently:
- CrimpOnAug 16, 2022Guru - Experienced User
Thanks. Driver date: 5/24/2022
- atiq020Aug 16, 2022Aspirant
Same as mine but i am using windows 10 home uptodate vers, only thing is when i select the mode in properties to ax or 6ghz its goes back to n/ac mode cant store or saved 6GHZ SETTING in windows 10, i also google help to edit Registry too but not helped
Not much the Orbi can do if the laptop will not let you use WiFi6E (or even WiFi6) Bummer.
