atiq020
Aug 14, 2022Aspirant
ORBI 960E NOT SHOWING WIFI6E ON MY LAPTOP
I change my windows 10 home addition wifi adapter to intel wifi 6e ax210 ALL Driver are upto date and Orbi ENABLE wifi 6E. mode. but still not showing on my laptop. my product details are using W...
- Aug 14, 2022
I have never seen anything definitive that Windows ever put out an update that successfully supported WiFi 6E under WIndows 10. There were lots of "We will support on this update and then we will support on this next update". I've seen other comments from Windows that says that you need to be on Windows 11 to have native support for WiFi 6E.
There were some methods using one particular driver set and some registry tweaks that kind of enabled WiFi 6E support but that was the towards the end of last year I believe. The only device I have with a WiFi 6E card even had some issues with that method.
I finally updated the one PC with the WiFi 6E card to Windows 11 (even though it truly didn't support Windows 11 due to one requirement) and have full WiFi 6E support and have had zero issues with running Windows 11 on the PC that did not meet 100% of the requirements.
atiq020
Aug 15, 2022Aspirant
Same as mine but i am using windows 10 home uptodate vers, only thing is when i select the mode in properties to ax or 6ghz its goes back to n/ac mode cant store or saved 6GHZ SETTING in windows 10, i also google help to edit Registry too but not helped
Aug 16, 2022Guru - Experienced User
I'll have to check, There was a specific version of driver that worked for me that was mentioned. I'll check my PC today and see.
I know TC_in_Montana may have some additional info on this as well as we were both using these drivers back then. I was able to get my AX adapter working and connected on my 9 series on Windows 10 back then.
- TC_in_MontanaAug 16, 2022Virtuoso
As noted in my earlier post - the only way I was able to get the 6GHz band recognized under Windows 10 was to use a specific (and now OLD) version of an Intel Driver and then it also required some other tweaks. Here is a link to the website that showed how to do it.
While this gave some access to 6GHz band under Windows 10, it was not consistent, and did not show true connectivity speeds, channel, and at times would drop back to 5GHz. It was truly a "work around" that worked sometimes.
It's not an Orbi thing, it's not a driver thing, it's a Windows thing - and Microsoft's desire to NOT fully support 6GHz under Windows 10.
- FURRYe38Aug 16, 2022Guru - Experienced User
There he is and that's it's.
Thank you TC_in_Montana
So heres my AX210 connected to the Orbi 9 series using v22.45.1.1 driver in Windows 10x64:
- atiq020Aug 16, 2022Aspirant
OK i c, so its mean i download previous version 22.45.1.1 not the current one. for windows 10 . i can find out old driver , can you tell me which website i can download old driver the one you used and also wifi scanner which u show its using 6GHZ plz
- TC_in_MontanaAug 17, 2022Virtuoso
For the wireless driver, you will need to use the link I posted (has dongknows in the website) and there is a download link there. It will take you to another website, with the download page.
Make sure you follow the directions in that link for how to install it - paying particular attention to which steps to follow based on current driver version.
For the WiFi Analyzer that FURRYe38 posted showing connection to 6GHz - you can get that from the WIndows Store. (It is free).
- atiq020Aug 17, 2022Aspirant
As far as i understand you using driver 22.45.11 On widows 10 and you getting 6MHz and 6E , Signal ?
- FURRYe38Aug 17, 2022Guru - Experienced User
6Ghz and yes.
My adapter card connects at 2400Mpbs on 6Ghz as seen on my picture there.
sorry i download and install the link you mention but there are not such 22.45.1 driver which you display , but i downgrade nearest driver , its wont work 6ghz or 6E . may be the removed such driver, there are few more so i tried 22.70.1 but its wont show 6GHZ
I'll send you a link to mine when I get home so you can get it there.
I think those links are out dated.
THANKYOU
Thankyou, i got the driver which you sent, but unfortuntly because i already install the current intel 22.150.3 latest its wont allowed me to go back , i uninstall and the driver but one its reboot its automatic download the latest one, i tried before reboot too but still cant go back.
i roll back to prevs driver and then tried but still error cant download you already got latest plz adviced
I forced the driver using the following method:
Update Driver
Browse my computer for drivers
Let me Pick from a list
Have Disk
Navigate to the folder were the AX210 drivers are located...
YES, MANY THANKS ITS INSTALL VER 22.45.1.1 but still showing 5GHZ. cant se any 6GHZ or 6E . I also tried to change MODE TO AX in advanced wifi setting. also my ORBI are already ENABLE 6/6E Can you screen shot what setting do i need to set in Advancd wifi mode. when i changed to wifi ax MODE its goes back to a/b/g/n/ac plz
After install 22.45.1.1 driver i also tried to change the mode to expand 6GHz and Auto. but when i click OK its goes back to First mode a/b/g/n/ac also i check in wifi list there no 6ghz adapter . and wifi analyzer still showing 5.2ghz .plz
I left everything default on the adapters advanced settings.
6Ghz=6E
ok i think might be its works for some i tried as its in advanced wifi or changed to set 6 or ax mode but its goes back to default a/b/g/n/ac first mode. anyway Many thanks alteast i tried with your help . nothing more u can do . many thanks . i will wait may b next update will do some changes.
Many thanks
Have you set up the separate 6Ghz SSID broadcast and see if your card see it?
Yes i just change diffrent name of 6ghz , Still not seen .
