atiq020
Aug 14, 2022Aspirant
ORBI 960E NOT SHOWING WIFI6E ON MY LAPTOP
I change my windows 10 home addition wifi adapter to intel wifi 6e ax210 ALL Driver are upto date and Orbi ENABLE wifi 6E. mode. but still not showing on my laptop. my product details are using W...
- Aug 14, 2022
I have never seen anything definitive that Windows ever put out an update that successfully supported WiFi 6E under WIndows 10. There were lots of "We will support on this update and then we will support on this next update". I've seen other comments from Windows that says that you need to be on Windows 11 to have native support for WiFi 6E.
There were some methods using one particular driver set and some registry tweaks that kind of enabled WiFi 6E support but that was the towards the end of last year I believe. The only device I have with a WiFi 6E card even had some issues with that method.
I finally updated the one PC with the WiFi 6E card to Windows 11 (even though it truly didn't support Windows 11 due to one requirement) and have full WiFi 6E support and have had zero issues with running Windows 11 on the PC that did not meet 100% of the requirements.
Aug 18, 2022Guru - Experienced User
using WINDOWS 10 HOME ALL UPDATED <Not sure if the HOME version is supporting of 6Ghz. Mines a Pro version.
WIFI INTEL ADAPTR AX210 6E all drivers upto date
ORBI WIFI 6E ENABLE 6E MODE
but still not show any wifi6e on my laptop?
- TC_in_MontanaAug 18, 2022Virtuoso
I am not sure if it is a Windows 10 Home thing or Windows 10 thing in general (like FURRYe38 ) I had a Windows 10 Pro version as well.
But, I am concerned about one other statement you made - and that is that you have tried to change the settings in the driver properties to use 802.11AX on the 5GHz band and it continues to revert back to AC. Am I understanding that correctly? You are going to the device manager, expanding Network Adapters, selecting the Intel AX210 card, right click on in and selecting Properties, then on the pop-up selecting the Advanced Tab, and scrolling down to 802.11 n/ac/ax Wireless Mode, selecting 4. 802.11AX and pressing OK?
If you do that, and it continues to drop back to AC, then that tells me maybe there is something wrong with that card. Either it is not installed fully, or maybe the antenna wires are not connected properly, or something.
Did you install this card? Did it come installed in that PC? Is there something in the BIOS maybe that you need to change? What brand/model is the PC? What brand/model is the AX210 card. Is it a separate card or is it a module that you installed on the motherboard? If a standalone card - what slot in the PC did you put it in? I've seen some of these card that require it to be in a certain type of slot and if you put it in an incorrect type of slot - it doesn't register correcting/work correctly.
You should at least be able to get to 802.11AX mode with this card on 5GHz - regardless of whether or not it can see the 6GHz channel (which again, may be operating system issue - not card or router issue).
OOOPS - Edited to add - It can't be a standalone card - I see you mentioned it was a LAPTOP. So it must be a Wireless Module - not a card.
- atiq020Aug 18, 2022Aspirant
Many thanks for Very brief reply. i install myself its INTEL AX210 WIFI 6E. its work fine , can connect to 5GHZ and 4GHZ . fine only i cant used 6GHZ OR 6E . I GOT DELL INPRION i7. laptop with windows 10 home update. i think card itself install correctly i attached antena wire to but not sure if its detached or not . but card install drivers automatic from intel driver assistance
its works fine on 5g or 4g. only issue cant find 6GHZ
- FURRYe38Aug 18, 2022Guru - Experienced User
Been mentioned that Windows 10 Insider build was needed to get AX210 working for 6Ghz.
https://community.intel.com/t5/Wireless/ax210-window-10-21h2-not-showing-6GHz-networks/m-p/1338022
Doesn't mentioned the variant here however I can only presume its not a HOME version.
Also:
https://kb.netgear.com/000064414/Does-my-Microsoft-Windows-PC-support-WiFi-6E
Windows 10 doesn't really seem to officially support 6Ghz so you may need to upgrade your Windows 10 to Windows 11...
