Retired_Member
Aug 01, 2023Orbi 963 Devices not connecting
I have the router and 2 APs in a ~3100 sqft house with a basement. Router is in the attic with one AP backhaul hardwired and the other wireless for now. Setup has been relatively good until rece...
- Aug 04, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Aug 02, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
This attic space well ventilated and cool?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
For that size of home, the RBR and just 1 RBS is needed. Can you turn off one RBS and observe?
- Retired_MemberAug 02, 2023
Firmware = 6.3.7.10_3.3.3 (latest available)
Don't know ISP info and can't see how that is relavent, given there are no issues with speed or access for the majority of devices and the problem devices once connected.
Router (attic) to wired sat (basement) is about 70'. Router to wireless sat (garage) is about 90'. Sat to Sat is about 140'.
Router sits in about 80 degree max space.
This only happens to a select few wireless devices. Namely my primary laptop Dell Precision 7530. Also affects a Lenovo W540, another Dell Latitude 5530. Also affects Sonos Arc, Sub, Beam, One, and Roam.
I have not tried isolating Orbi devices since they all work together the configuration should be seemless and act like one device. The point of mesh right? System indicates this problem laptop is connected to the router.
Primary target is the Dell 7530, any drop in wifi, toggling of radios, or reboot results in no auto reconnect. I MUST open the settings and click connect 30-45 seconds later I finally get a connection. Almost like the router/armor has blacklisted certain devices. How do you clear that?
Wireless config is attached. Closest neighbor us about 500' away.
- FURRYe38Aug 03, 2023Guru - Experienced User
ISP Info is relevant as we are trying to establish if there is a router and wifi here or not. Can cause problems. Reason why we ask.
What CAT# LAN cable are you using to connect the RBS to the RBR? CAT6A is recommended.
Over time, heat will damage the Orbi units. This would not be recommended.
Be sure any ethernet or wifi adapter drivers are updated on the PCs or Laptops.
Disable Armor and see if this changes anything.
Try channels 1 and 40.
- Retired_MemberAug 03, 2023
Don't know ISP info and can't see how that is relevant, given there are no issues with speed or access for the majority of devices and the problem devices once connected.
Spectrum ES2251 Modem. DOCSIS 3.1eMTA. Does data and voice. I do not use the voice.
Router (attic) to wired sat (basement) is about 70'. Router to the wireless sat (garage) is about 90'. Sat to Sat is about 140'.
Cables are CAT6, not possible to change this.
80 degrees seems reasonable for electronics. However, I will move it to the other side of the wall to keep it 6 degrees cooler.
I have not tried isolating Orbi devices since they all work together. The configuration should be seamless and act like one device. The point of mesh right? System indicates this problem laptop is connected to the router.
All drivers are current. That was my first step.
Disabled, no change.
Wireless config is attached. Closest neighbor is about 500' away.
Channels set, no change.
