306Orbi
Jul 03, 2022Star
ORBI 963E And Which Satellite Acquires A Device
I know this has been discussed before - but my purpose of this post is if someone has figured out a way to solve this problem in a ORBI 963E and Satellites System. I have a ORBI 963E Router and 3 Sa...
- Jul 03, 2022
Because its upto devices to pick and choose where they connect too. Not Orbi.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Jul 03, 2022Guru - Experienced User
306Orbi
Jul 03, 2022Star
House is 8000 Square Feet.
The distance between router and each satellite is over 30 feet.
I will try the lower the RBR signals to 50% - then reboot the system and Report Back,
Thanks for helping.
